Labeling Points Using Label Points and Feature Code Processing plus Leader Lines
This week I have had a few requests for help relating to labeling points either imported from a CSV file or from a Siteworks SPJ file or an Access JXL file and how best to label them and then manipulate the labels so that they do not overwrite each other.
We also hear a common question relating to the standard labels that you can turn off / on in the View Filter Manager for Point ID, Description and Elevation and how you can manipulate those to clean up a drawing - bottom line is that you cannot manipulate those until you have labeled points with labels or smart text - then they are true CAD objects that you can manipulate, add leaders to, move the text around etc.
The video shows you how
