How To Merge Multiple Surfaces In One Process
This has come up a few times recently. The Merge Surfaces command only allows you to merge one surface with another surface. What if you have several areas that have changed on a project and you have several patch updates to make to the design model?
The video shows how you can combine the patches into a single surface and then merge that combined surface with the Target Surface in one step. Saves a lot of time …
