How do I create Surface Models from Point Clouds with varying point density?
Often when you are modeling a site from point cloud data, there will be some areas of the site where a low density of points will suffice, and in other areas you want more detail extracted from the point cloud for a higher resolution surface model.
In this Technical Reference Document, I cover Point Cloud modeling techniques that you can adopt to achieve this requirement.
Technical Reference Document - Point Cloud Surfaces With Variable Point Density Areas.docx (4.3 MB)
