In this post we will capture tips that you may find helpful on using Google Earth
Tree Canopy Removal
In Google Earth if you have a lot of tree areas on your project, if you turn off the 3D Buildings layer the trees also will disappear making your Cut Fill Maps easier to see over the entire area of your project.
Clamp to Ground vs Absolute
If you publish data in 3D as “Absolute” you can see the Fill Areas in Google Earth but not the Cut Areas - if when you export the data you apply a Google Earth Offset of say 25’ then the site will be raised above the Google Earth Ground Surface so that you can see it in context, just not at the correct elevation - this when combined with a CF Map that is draped over the surface in Google earth can provide a great way to visualize the project data
Clamp to Ground basically drapes the image or CAD objects over the Google Earth Terrain Surface
Absolute creates the linework etc. in 3D at its true elevation, note however that some will be above Google Earth Terrain (Fill) and some will be below Google Earth Terrain (Cut). I have not yet found a way to show Cut areas effectively at Design Elevation in Google Earth - if anyone has any tips on that please let us know.
