In the video below we show you how to create a Rock Surface Strata Model using imported Rock Strata Contours rather than Boring Log data. If the Contour data is provided as Elevation Contours then your strata model has to be of type Elevation for you to be able to add 3D data to the surface using Add / Remove surface members. If the Rock Contour data is Depth based i.e. 3’ below OG, 5’ below OG etc. then your strata surface model has to be a Depth surface model to use the data.
The process is fairly straight forward and uses the fact that you can Add / remove Surface Members to a strata surface in the same way that you can do that to any other surface model.
Video shows you how
In this follow up video we show what happens when the Original Ground model has contour or other data and how the rock strata surface gets formed in that situation.
Hope that this helps
