I recorded this video in response to the request to build a binned survey model on 2.5m centers from a small boat hydrographic survey collected with a Single Beam echosounder. I used the RPScommand Points to Grid command that was originally written to BIN machine data collected at the tips of blades for a machine operation, however the binning process is the same - specify the grid and the grid axis using an alignment, and then define whether you want the Highest, Lowest or Average points or all in each of the grid squares and then form a surface model from the results.
The video shows how this is done.
