About the TBC - Machine Data Service category
The Machine Data Service allows users of TBC to tap into production data captured by GCS900 and Earthworks machines in VisionLink to create point clouds, heat map overlays and to interrogate the data in a similar way to what is possible in VisionLink. You can use TBC tools to produce drawing and cross section or profile deliverables for projects, to create an edit surface models and contours and to create compaction drawings.
This Technical Reference Document covers what is possible and how to set the system up to work with your Visionlink installation.
Machine Data Service - Setup and Use.docx (3.6 MB)
